Achieving < 1ug/√Hz at 1 Hz using ADXL355 module
shahriar193
Associate II
Is there any way to achieve this desired noise sensitivity using the ADXL3555 accelerometer. Maybe using filter? Appreciate the help.
1 ACCEPTED SOLUTION
Accepted Solutions
Peter BENSCH
Welcome @shahriar19, to the community!
You took a slight wrong turn in your search for support for your MEMS sensor: STMicroelectronics also has such sensors in its range, but the ADXL3555 is not a product of STMicroelectronics, so it is unlikely that anyone here can help you.
Good luck! /Peter
2 REPLIES 2
Peter BENSCH
Good luck! /Peter
Thank you for your answer. Can you suggest any sensor that has noise sensitivity of < 2ug/√Hz at 1 Hz. The frequency range can be 1 to 100 Hz. Any suggestions will be appreciated.
