2021-09-23 5:17 AM
I am using a STEVAL-ISC004V1 to power up a device (PD sink) that needs 24W (15V 1.6A) power supply to power up and charge the battery.
When I connect the STEVAL-ISC004V1 to the device the VBUS LED does not show a solid green and flashes. My device also shows that it is charging while LED is on, and shows disconnected from power when the LED is off.
How can I fix this problem?
