2014-04-28 7:28 AM
I just received a STEVAL-IDW001V1 eval module. It is meant to connect to a Discovery F0 board, but intend on using it with a STM32F215 processor based device. I haven't found much documentation about this eval board. I have: STEVAL-IDW001V1 - Wi-Fi daughterboard for STM32F0DISCOVERY which includes a schematic and a general outline of what the board can do. No specifics as to what the jumpers are for, what the important connections are, etc. STEVAL-IDW001V1 Schematic diagram This seems to have no relation to the eval board??? SPWF01Sx - Serial-to-Wi-Fi b/g/n intelligent modules This does, at least, give pin-out for the WiFi module being evaluated alond with some min/max ratings. And, the most useful so far: SPWF01Sx AT Command set reference guide Is there any detailed info on the eval board, or is this it? Thanks for any additional info! Vance2014-05-05 3:21 AM
Hi Vance,
we are working on st.com/wifimodules documentation. It will be more rich of informations from the end of May on. - SPWF01S Datasheet -> go to www.st.com/wifimodules, click on SPWF01Sx, then ''Design Resources'' into new tab - IDW001page:http://www.st.com/web/en/catalog/tools/PF260012 (again, click on ''Design Resources'') In Attach: -IDW001 HowTo - SockServer HowTo Thanks for feedbacks ________________ Attachments : SPWF01Sx___Socket_Server.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0ei&d=%2Fa%2F0X0000000bmq%2FqQuJUohAQafLATflMqubVDecKW35zGMlUllBywbm.eg&asPdf=falseSPWF01Sx_and_STM32F0-Discovery.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1QC&d=%2Fa%2F0X0000000bmm%2Fw8MU4Vl4Y1RDXld9WADjkUcvMIG9SY3x_K8zB1V74ug&asPdf=false2014-10-13 3:12 AM
Welcome for the first time on this forum.
I try to use SPWF01S in my projects, unfortunately I met unsolvable problem for me. I would like to ask you for the information, how to save a set of html pages to an IMG file (as in STEVAL-IDW001V1) so that it can be send to the module by a command AT + S.HTTPDFSUPDATE. Which tool creates this file?Best regards2014-11-19 6:36 PM
sorry for delay. Please contact your local ST support. He will send you that tool. It builds an ''*.img'' file, starting from a directory containing target filesystem content. Thanks jerryWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
