2016-12-19 5:48 AM
Hi Jerry,
is it possible to save the network connection settings (SSID name, password, etc.), that after a firmware update of the SPWF01the settings are still avaliable and the module connects again to the network?
In older firmware upates, I have to setup the module with the network settings again after a firmware update.
Cheers,
Flow
#firmare-update #spwf01Solved! Go to Solution.
2016-12-19 9:20 AM
Hi Flow,
usually a FW update reloads factory setting if configuration variables have been changed. In this case, a specific WIND appears on console (WIND:73).
If configuration variables are not moved/changed/etc from different FW versions, than WIND:73 will not appear on console, and user variables are not lost.
Hope it clarifies
jerry
2016-12-19 9:20 AM
Hi Flow,
Hope it clarifies
jerry
2016-12-21 2:00 AM
Hi Jerry,
thanks for explaining.
So, I will save the network settings before I update the module...
Cheers,
Flow
