2018-07-10 6:37 AM
Do you have any automotive option of SPBTLE-RF or SPBTLE-RF0?
Best regards
Mich
2018-07-11 1:54 AM
Hi Mich,
neither SPBTLE-RF nor SPBTLE-RF0 are automotive grade.
As reported in the datasheet for both modules (based on the BLueNRG-MS chip), suitable applications are:
Out of curiosity, what kind of application are you targeting? Is it going to be an aftermarket solution?
Best regards,
Antonio
2018-07-11 2:33 AM
Hi Antonio,
Asset tracking market.
Do you have another reference to advise?
Best regards
Mich
2018-07-12 2:50 AM
Hi Mich,
for the time being, ST solutions for BLE are not automotive-grade.
For the asset tracking market, depending on the specificity of your case, you may probably need to have an automotive certification, as your solution might interfere with other electronic equipment in the vehicle. Nevertheless, everybody is using smartphones in the car, even if they're equipped with many non-automotive RF components.
Based on your marketing requirements, in case you're not obliged to use automotive parts, I'd suggest to use a module with the newer BlueNRG-1/2 chip, like the
.Best regards,
Antonio
