SPBTLE-RF automotive
Posted on July 10, 2018 at 15:37Hello,Do you have any automotive option of SPBTLE-RF or SPBTLE-RF0?Best regardsMich
Posted on July 05, 2018 at 21:12Hi,I'm using BlueNRG-MS to transfer data to host PC running windows 10.The connection interval is 15ms, slave latency 5, connection timeout of 300 ms. BlueNRG-MS sends 1 notification of 20 bytes each connection (verif...
Posted on July 09, 2018 at 13:01Good day, everyone,I have tried using the ST7590 QFN chip and I found that its functionality is limited, and the TQFP package is the advertised stand-alone chip. I have been advised (if I am going to make a change) I ...
Posted on July 09, 2018 at 20:07Looking for someone who is working on asset management with bluetooth mesh, wifi and maybe RFID. we are starting on a new project with asset management and would like to work with someone on this project.
Posted on July 09, 2018 at 16:42I am trying to receive CANopen data (8bytes sent every 1s) with Nucleo L476RG (it has only Master CAN interface but I think it should not matter since CAN is multimaster). For conversion CANH and CANL to CANRx and CA...
Posted on July 09, 2018 at 11:29What is the supply voltage range for ST485E.The datasheet doesn't give a minimum for the range
Posted on July 01, 2018 at 16:21Hello, I am trying to develop a new product with the SPBTLE-1S module, my idea is to use the module connected to a uC by UART.https://www.st.com/resource/en/datasheet/spbtle-1s.pdf Looking in the datasheet I see that ...
Posted on July 04, 2018 at 12:44Hello,I am using BluNRG-1 module with Stack v1.0.My clock source is 'LS_SOURCE = LS_SOURCE_INTERNAL_RO', the module has no external oscillator.I used the following code to lower the power consumption, as it is adviced...
Error while parsing Rich Text Content
Posted on May 02, 2018 at 20:11Hello,Where can I find the source code for the Demo Android Apps, such as the 'BlueNRG' app or 'STM32 BLE Profiles' app.Thanks,Ricardo#android-app #bluetooth
