2021-06-23 1:43 AM
Is there any available circuit/schematic where external PA has been used to enhance the power output of S2LP at 868 MHz operations? I am trying to understand how do I work around BALUN suggested for S2LP 868 MHz (FKI868V2 kit) with an external PA?
2021-06-23 4:29 AM
Reformatted and moved to proper Q&A (topic is not about ST25 products).
2021-06-23 7:01 AM
Please refer to STEVAL-FKI915V1, which is proper to operate at 868 MHz.
The PA is Skyworks SE2435L.
Schematic can be found:
https://www.st.com/resource/en/schematic_pack/steval-fki915v1_schematic.pdf
2021-06-30 12:17 AM
Hi Winfred,
Thanks for the answer.
Can I also know if it is possible to observe data transmitted in Tx modeofS2LP on the oscilloscope? Or is there any way to observe this data which is sent on air?
best,
Nilesh
