2022-03-08 3:19 AM
For a project we need to simulate PSI5 sensors.
We choose the ST L9663 but it can’t send PSI5 frame. It can only be used to send PSI5 sync pulse to sensor. It can only interface master to slave.
I have searched on many website but I can't find a component who can send PSI5 frame.
Is there any transceiver who can send PSI5 frame ? To simulate a PSI5 sensor.
Thank you in advance
Best regards,
Anthony
2022-04-11 2:39 PM
It is easier to buy a real PSI5 sensor instead. In my company we have an FPGA based emulator for a real PSI5 sensor emulating but this kind of tools are not available in market, usualy made for internal use.
2024-09-11 12:53 AM
Hi, I am now trying to choose L9663 to simulate sensor, so how do you simulate sensor finally? Is there any avaliable IC to do this? Thanks.
2024-11-13 8:56 PM
Any update on this? I also want to simulate the PSI5 sensor, and I went through the L9663 datasheet, and found that it can only receive PSI5 data from sensor, but could not send PSI5 frames.
Does ST have such IC could simulate PSI5 sensor?
