2020-05-05 4:28 AM
I really appreciate the reactivity of the forum, thanks a lot.
i have some questions:
1- When i enable/disable LDC mode using S2LPTimerLdcrMode, and S2LpTimerFastRxTermTimer, i need to run command S2LPCmdStrobeReady and S2LPCmdStrobeRx after each enable and disable?
2- When i have TX_FIFO_ERROR, i need only to run S2LPCmdStrobeFlushTxFifo, S2LPCmdStrobeReady, S2LPCmdStrobeRx (last two command to prepare S2LP fo RX)?
3- Sometime i have IRQ status 0.0.0.0 what does't mean? Is't a problem of collision, because i see this problem when S2LP try to send message and a new message is received?
4- when i use mechanism of Infinite preamble as described in application note Sniff Mode application (and my chip is also in LDC mode) how i will be sure that the receiver will be wakeup? in other word, how i will be sure that my msg (not the msg of infinite preamble but the real msg) will be in the Fast RX timer of the receiver?
Thanks in advance.
2020-05-12 10:29 AM
