2020-04-24 4:49 AM
Hi community !
I need your help with Light example for BlueNRG-2. I want to add ble to this example, like that i can use PC to communicate with the card by BLE and then this message could be transmit to mesh.
What do i have to activate to archieve that ?
Thanks for your help
2020-04-28 8:37 PM
It means you need to add a GATT connection ? This is not supported right now.
The reason is that the BLE connection is managed by BLE-Mesh firmware. You can however, use UART interface to make connection to the PC.
2020-04-29 1:07 AM
Thanks for your reply. I want to avoid cable between PC and BNRG-2 card, that's why i use BLE Mesh. Is there any other option to archieve that ?
Thanks again
Sincerly
