2026-05-11 1:37 AM - last edited on 2026-05-28 2:14 AM by Andrew Neil
I noticed that the MB1720 High_band Low_power configuration and the MB1720 High_band High_power configuration have different input line differentials. I would like to know, when combining High_band/Low_power nodes with High_band/High_power nodes in the same RF mesh network, what design considerations should be followed and how the part should be designed?
Thank you.
2026-05-12 11:10 PM
To confirm my understanding: are you asking how to design a single matching network that supports both 864 to 928 MHz at 15 dBm and 864 to 928 MHz at 22 dBm configurations, given that we recommend different reference designs for each configuration?
Best regards
Saverio
