2022-01-08 12:53 AM
i use bluenrg2 as main mcu , to control a ac 220v ac contactor , the main logic is
bluenrg2 -> Optocoupler -> DC 12V relay -> AC 220V ac contactor
If i open/close, the bluetooth will disconnect and will crash very often. Is it not suitable for my case
2022-01-08 2:37 PM
Sounds like an EMC fail - your design is over susceptible to conducted and/or radiated disturbances from the contactor and/or the load switching.
Start by looking carefully at your supply lines:
2022-01-09 5:33 AM
could you help me to check the schematic?
2022-01-09 4:52 PM
You'll have to post the schematic if you want people to check it.
And it's not just about the schematic, the layout is also important - so you'll also need to post some good, clear, in-focus photographs of your setup.
