2017-03-30 4:05 AM
Hi All,
I have question about BLUENRG-1, can it run as stand alone without another MCU?
If yes, I would appreciate very much if you could refer me to some references.
Regards,
Nav Dev.
#bluenrg-1 #standalone-mode2017-03-31 2:05 AM
BlueNRG-1 is a standard Cortex-M0 so it can run as a stand alone MCU.
All documentations and the SDK can be found in the following link:
http://www.st.com/en/wireless-connectivity/bluenrg-1.html
.Regards,
Julien
2017-03-31 10:28 PM
Thanks Julien for answering,
But you refer me to all the documentation of the chip, and i can't find any document related to how to set the bluenrg-1 as stand alone, and which components(hardware like another flash..) i need.
Can you please spasifi which document related to set as stand alone?
Regards,
Nav Dev
2017-04-01 2:57 AM
Regarding the hardware part, you can have a look at the application note AN4819:
You won't need an external flash to run BlueNRG-1 as a stand alone MCU.
If your first step is to evaluate BlueNRG-1 then I recommend you get a BlueNRG-1 evaluation board:
With this board, you can have a good idea on how BlueNRG-1 works and start prototyping your own application.
Regards,
Julien
2017-04-02 4:48 AM
Thanks a lot Julien, have a nice day.
