Dual STUSB4710 Power Management
I am designing a usb type-c charger. I want to use 2 microcontroller and 2 STUSB4710.Type-C Output will be 20V 3.35A 67W.I want to do power management between these USB Type-C outputs.I have questions. Can you please answer them? 1. Are there any I2C...
Resolved! Camera controller
Hey team,I wanted to check if there is any bridge IC  that can convert parallel camera interface data to USB 3?And/orDo we have anything that can convert MIPI CSI-2 to USB 3? - again for a camera IC.Thank you for your help!
Ilker123 by Associate
  • 1838 Views
Resolved! Zigbee identify and groups cluster
Hi evryone,I've been trying to work on Zigbee communication for a while now, so far I've just learned how to read and write attributes. Now I'd like to try to learn how to use cluster Identify and groups, but I dont understand several thing, so I nee...
CH3 by Associate II
  • 17349 Views
  • 12 replies
Resolved! BlueNRG-LP I2C1 and I2C2 coexistence
hello community,I´m using PB10/PB11 as I2C1 and PB6/PB7 as I2C2.I2C1 works correctly.But I2C2 not, after reset on PB6 and PB7 I just get some messy signals as below, It seems the I2C2 is not initialized with succcess.Actually the both I2C are initial...
Demo board for STOTG04
1.Is there a Demo board for STOTG04? If so where can I procure it?2.It is given in the datasheet that STOTG04 supports OTG so how Vbus is being switched during host and device?
