Use STEVAL-IDB008V2
Hi all, I've just bought a STEVAL-IDB008V2 board, but I don't find any tutorial or ressources like get stared, the only doc I've found is https://www.st.com/resource/en/user_manual/um2094-getting-started-with-stevalidb007vx-stevalidb008vx-and-stevali...
SBaro.11 by Associate III
  • 784 Views
LIS2DU12 reset / drdy interrupt
Hi,I am working on the LIS2DU12, but unfortunately it does not yet work as I expected. I do a reset and wait with the status bit of reset until it is done. The system is therefore in power-down.  I then set the drdy. This immediately triggers the int...
JasperLI by Associate
  • 757 Views
STUSB4500 NVM Customer Sector0-4 Write
Hello, this is LewisI have a question about "STUSB4500 NVM Customer Sector0-4 Write".I would like to know the message below from the technical note "STUSB4500 NVM Register Description and General Access".(attach file)"Load NVM data sector 0 (8 bytes)...
luisfynn1 by Associate III
  • 1227 Views
Resolved! L9663 SPI minimum configuration
   I can't get my L9663 SPI working. My understanding is that any 32-bit data I send to MOSI will return a 32-bit data from MISO. However, I am not getting any response; MISO remains low the entire time.    I am now using a QFP32 general adapter boar...
Leomost by Associate II
  • 2335 Views
