ble disconnection with sleep mode
Have a nice day! I use the Bluenrg-2 chip. As the base project, the Power Consumption Test example is used. The example works fine. But when I use these sources with my bootloader project, a connection problem occurs with BLE_HCI_CONN_FAILED_TO_BE_ES...
rhetti by Associate
  • 910 Views
FreeRTOS support for BlueNRG-2?
I am evaluating Keil MDK5 for programming my BlueNRG-2 device. I have found that I cannot create a project from scratch with any RTOS support because the CMSIS driver seems to be lacking the Device.Startup section. Looking in the SDK examples for the...
BBeau by Associate
  • 2000 Views
  • 4 kudos
S2LP SMPS1 VOLTAGE PROBLEM
Hello;My Name is FATIHI am using Wireless MBUS water meter scanning using S2LP and STM32L073. While making the PCB design, we applied the reference design value in the x-nucleo-s2868a2_schematic.pdf file exactly. However, although we see VDD voltage ...
FATIH55 by Associate
  • 1042 Views
ESP32-C3 and VL53L4CX no I2C Signal
Hi! I am trying to built this ToF rangefinder using this tutorialBut instead of using the VL53L0X I am using the VL53L4CXI have attempted with 2 different ESP32-C3 Controllers and 2 separate VL53L4CX sensors and no matter what I do I can't get any I2...
