SPWF01SA UDP Connection Inconsistent
Posted on January 29, 2016 at 14:05When I configure one module to listen on a port I can then connect to it via PC client and enter data mode. At this point a link is established and communications are asynchronous bidirectional. When configuring o...
jgarr by Associate II
  • 1511 Views
BLueNRG ACL packet 4-8 seconds waiting for event
Posted on January 26, 2016 at 19:54Hello.Why when I use sending of ACL packet it is take to 4-8 second for acknowledge event?How can I  setup this duration?Which type of ACL packet does BlueNRG use?( DM1, DH1, DM3,DH3, DM5, DH5 and AUX1.  2-DH1, 3-D...
namoaton by Associate II
  • 699 Views
SPSGRF - Spirit1 configuration
Posted on January 25, 2016 at 16:37 Hello, I have bought 2 SPSGRF-868-Nucleo module. I want for beginning sent a packet for see how spirit1 works. But afters some search, I don't know if my packet is really sent or not because I receive a...
BLueNRG IRQ?
Posted on January 15, 2016 at 17:30Hello. Could you tell how IRQ is work? Does setup automatically after command write to BlueNRG over HCI? #bluenrg #spi #hci
  • 741 Views
Temperature of the SPWF01SA
Posted on January 21, 2016 at 13:33Hi everyone, I'm making a comparison of different SoM for IoT. I found the SPWF01SA which matchs with my needs. But I want to know the heat generated by this module. Does someone have this data ?
Data Mode to Command Mode
Posted on January 22, 2016 at 10:02Hi!I have connected my Wi-Fi module  with a client and now I am getting the commands+WIND:61: Incoming Socket Client :172.31.142.2+WIND:60: Now in Data Modenow I want to get back to  command mode.I have tried hitti...
Nandy K by Associate II
  • 3186 Views
  • 13 replies
How to customize the advertising packet?
Posted on January 09, 2015 at 18:46Hi, I'm trying to customize the advertising packet, but it's unsuccessful so far. I use STEVAL-IDB002V1 BlueNRG HW v3.0BlueNRG FW v6.4Motherboard FW v1.4Since the command ACI_GAP_SET_DISCOVARABLE doesn't give much ...
dimitar by Associate II
  • 5663 Views
  • 11 replies
