aci_gatt_update_char_value fails
Posted on January 07, 2017 at 08:54The function aci_gatt_update_char_value fails initially....and if fails there is while(1) loop...so system stuck here....what is issue ? after debugging it observed that function returns BLE_STATUS_TIMEOUT.....can ...
milind2 by Associate II
  • 2579 Views
aci_gatt_update_char_value fails(BlueNRGMS)
Posted on January 09, 2017 at 10:54The function aci_gatt_update_char_value fails initially....and if fails there is while(1) loop...so system stuck here....what is issue ? after debugging it observed that function returns BLE_STATUS_TIMEOUT.....can ...
  • 1358 Views
BlueNRG-MS Dongle fails to update FW
Posted on January 05, 2017 at 22:35I am trying to update BlueNRG-MS FW (using IDB006 Eval Bluetooth Dongle) using GUI -> Tools -> BlueNRG Updater -> BlueNRG-MS (v3.1 and above) -> bluenrg_7_2_c_Mode_2-16MHz-XO32K_4M.img (Tried 7.1 FW too)However, GU...
STEVAL-IDB007V1- debug problem
Posted on January 05, 2017 at 09:39Hi, I'm working with the board STEVAL-IDB007V1 and it works correctly with the PC Tool BlueNRG-1 Navigation. I have some problems when I want debug the project Demo sensor: I tryed to use ST-LINK and also the J-LIN...
Spirit1 strange state
Posted on January 03, 2017 at 19:08Hello.What could be the reason for Spirit1 (SPSGRF) module getting stuck in 0x3B PM_setup state? Everything works well until one RX state timeouts (doesn't receive any data).Thanks#spsgrf
SPBTLE-RF disconnection problem
Posted on December 26, 2016 at 09:13I am using the SPBTLE-RF connected to a standalone MCU to communicate with my PC using BLE.I am establishing the connection and the data is being transferred ok but every X minutes I encounter a drop in the BLE co...
SP1ML Microcontroller question
Posted on December 21, 2016 at 21:46Good evening,I have a question about the SP1ML module: it integrates Spirit1, baloon, chip antenna and the STM32L151RB microcontroller.I search info about the STM32L151RB in yur site and I saw there are 2 version:...
