SPW40SA Certificate Error:23
Posted on January 13, 2018 at 15:07Hello Everyone,Even if I load the DER binary format into my wifi-module SPW40SA , The subject key identifier won't be detected automatically by the module. I have to manually add the key and if I try the simple AT+...
Bonding problem
Posted on January 03, 2018 at 17:23 Hi, I'm using BlueNRG as bt peripheral. I can successfully pair my android smartphone, but the BlueNRG doesn'tadd the smartphone to the bonding list. aci_gap_init(GAP_PERIPHERAL_ROLE, 0x00, 0x08, &Bluet...
SPWF04 HTTP POST Problem
Posted on January 09, 2018 at 14:30Hello, everybody.I want to use HTTP client mode. I should send the next message: api/Tokens?username=test&password=123456789&serialnumber=123456789to the server:https://messagebus.example.comand get the response. I...
SPWF01SA in Socket server mode
Posted on January 11, 2018 at 17:24Hello,I'm using the SPWF01SA in Socket Server Mode. My intention is to send to a browser an html page when the browser ask it to the server. I chose to use the port 80, so I disabled the internal webserver. I open ...
nataut by Associate III
  • 667 Views
BlueNRG-MS dongle
Posted on January 11, 2018 at 14:37I am using a STEVAL-IDB006V1 MS dongle.For instance, let 's suppose that using this DONGLE with the SensorTile KIT, and that instead of doing int by script thorugh the BLUENRG GUI , i want to modify the dongle firm...
