SPWF04S Factory Reset at power cycle
Posted on January 29, 2018 at 13:55Hello,We see a Factory Reset:1 When power cycling the SPWF04S. In about 80% of the times.It is setup as a mini AP when the power cycle is done. Since the host is running lower UART speed than the SPWF04S it complic...
Transmit power issue in SPWF01SC.11
Posted on April 27, 2018 at 15:58We are using SPWF01SC.11 in the design and FW version is 3.5.3 (170111-665d284). When we send the command 'AT+S.SCFG=wifi_tx_power,12', We are not consistently getting positive response from the SPWF01 module. Please...
SPWF01 MiniAP connection problems
Posted on April 27, 2018 at 14:03Hello,I am using the SPWF01 (FW 170111) WiFi module together with a STM32 host controller to build a MiniAP with TCP socket server. Data is transfered in DataMode.In principle it's working fine, but:1. Some user can'...
