SPBTLE-1S Multi-Channel ADC?
When I read one channel, I get good numbers (using the polled version for now).When I change the MUX after a read to go to the other channel (ADC2, Temperature), I get garbage on all channels.I've read/discarded 12 readings, but even that doesn't eli...
TJohn.14 by Associate II
  • 709 Views
Resolved! Kindly give the solution for error: No signature of method: com.crashlytics.tools.gradle.CrashlyticsPlugin.findObfuscationTransformTask() is applicable for argument types: (java.lang.String) values: [ReleaseUnsigned]
I downloaded the latest version available at ST site i.e. Ver 1.07. When I am trying to sync the project the error appears. Same happens with old version also. Kindly help.
NKall.7 by Associate II
  • 1634 Views
Resolved! BLE_SensorDemo from Blue Tile DK source file issues.
Compiling the BLE_SensorDemo sources in True Studio does not generate the same .hex as the precompiled .hex provided in the "Firmware" directory. The precompiled .hex works with the BLE Sensor app when loaded onto the BlueTile, but the .hex compiled ...
BPaik by Senior
  • 1000 Views
Resetting Embedded ST-LINK Debugger on STM32F411RE
Hi, i have a problem and don't find any solution yet. ​I do some mistake and st-link part of my board doesn't communicate to mcu part. ​Actually I'm not sure the problem but, when I search all internet and assume that the problems is this. ​When I co...
Oladi by Associate II
  • 1602 Views
BLE_STATUS_TIMEOUT from Bluenrg-MS
Hello, I am trying to send sensor data through BLE.Below is my code I am getting BLE_STATUS_TIMEOUT (0xFF) from getBlueNRGVersion fuction as shown in code I am printing hex value just to know return val.After that every functions returning same erro...
DPate.5 by Associate
  • 929 Views
S2-lp and mesh stack
Hello, Is s2-lp RF module supports mesh? If yes, where can'i found mesh stack and how it can be used? ​Is below application note describe how can'i configure s2-lp module to work on mesh network? https://my.st.com/resource/en/design_tip/dm00567382.pd...
BMoha.19 by Associate II
  • 854 Views
