Hi Sir, I am working with BluenrgMS stack all things are well with ios but android BLE apps are unable to scan bluenrg devices.I have tried every solution posted in this community, but none works.why it is so only with android.
Do you have a solution of BLE 5.1 direction finding? If yes, where can I download it? If no, do you plan to provide it or not?
I am interested in the implementation of Bluetooth 5.0 from ST. In describing some of the chips I've seen that meets Bluetooth v5.0 specification. But it is not clear whether there is a "Long Range" support.Where I can see this information?
I understand the data format to be little endian and can someone show where the format is explained? As an example please decode C7 38 which occurred around 17:26:58.Thanksralph
Hi EnricoCan you please suggest us the correct values for data rate, deviation and channel filter for the sp-l2 in a narrowband application?How narrow can we go?Also in your schematic you use a trimmer for calibration .Why? Isn’t the tcxo precise eno...
Hi,we want to have a possibility to disconnect the USB-C supply manually.Can we use the VBUS_EN_SNK signal and disable the corresponding mosfet manually?The datasheet is somehow unspecific.Is the VBUS_EN_SNK signal undriven when we set the device via...
I'm working on a central BLE device. I'm having some trouble with the sensor and the hub not being in sync. It looks like that the central device wakes up to late, every 3rd wake event the central wakes up at the right time and a PDU is sent/received...
