IODD files for STEVAL-IDP003V1 (IO-link device)
Hi all,I have purchased the evaluation kit STEVAL-IDP003V1 (IO-Link device) and want to test it with a master of Siemens (it supports both versions). But I need the IODD files for the master configuration and can't find it anywhere. I already tried ...
Luis1 by Associate
  • 786 Views
Hi All, I'm using STUSB4500 as USB Type C PD controller. When am connecting type C cable from adapter to the board it is able to power up. But when I remove the cable and connect again it is not powering up.
For the next time I have to re-connect the adapter than re-connecting type C cable for powering the board. Please help me to find a solution for this issue.Regards,Vyshnav Krishnan
Vvk.755 by Associate II
  • 3508 Views
STML011K4 Stopmode consumes too much current.
Hello,Running my program on the STML011k4 consumes about 50mA, when in stopmode this drops down to about 40 mA. I know the stopmode does still power the RAM, but 40mA is way too high according to the datasheet. Another thing I find odd is that the LE...
SPlat.1 by Associate
  • 673 Views
FOTA with IoT kit discovery node
I'm trying to get basic FOTA working with the example binary from en.fp-cld-azure download (Azure_IoTCentral_BL.bin).I have the example binary loaded on the board and successfully connecting and communicating with my Azure IoT Central app.I added the...
DSabo by Associate III
  • 683 Views
