Sniff mode
Learning how the module works in scan mode. I found in the examples (S2-LP DK) two functions which I do not understand. S2LPTimerLdcIrqWa и S2LPManagementGetCut. The first function is how I understand how to change the module to sleep. And the second...
IDavy by Associate
  • 881 Views
Resolved! Integrate Beacon application with Mesh
Hi All,I am using BlueNRG-1. I wanted to integrate beacon code (i.e. BlueNRG-1 DK 2.3.0\Project\BLE_Examples\BLE_Beacon) to Mesh code (i.e. STSW-BNRG-Mesh\Firmware\Projects\BlueNRG-1\Applications\Lighting_Demo). I want both the code to work from a si...
Vibhu by Associate
  • 1326 Views
STKNX problem
Hi, I am using STKNX interface circuit on my KNX device below and i am facing with a strange problem. My device is working clearly on a KNX line but, when i plug a parallel twisted pair cable to my device KNX input (the other side of cable is open i...
er3481 by Senior
  • 1371 Views
How to solve the bluenrg-ms initialization fail?
​I made a custom board with BlueNRG-MS.However, the initial response is not correct after reset - compare with chapter 3.5 Test procedure in the AN4494.The first message after reset is correct, but the response is invalid from the 2nd reply.04, FF, 0...
just4you by Associate III
  • 2330 Views
What is the best design for bluenrg-ms?
I desgined custom board with bluenrg-ms which I bought in the mouser.com.Therefore, I can't figure out what firmware the ic has.My first reference is sensortile.Because the schematic is very simple compare to the development kit.Currently, my board i...
  • 1180 Views
