Resolved! BlueNRG-LP Insufficient Resources
Hi,Whenever i call aci_gatt_clt_disc_all_primary_services() or aci_gatt_clt_exchange_config(),the stack returns BLE_STATUS_INSUFFICIENT_RESOURCES (0x88).What exactly is insufficient? Is it the heap size of the stack is just busy?What adjustment do i ...
JLee.46 by Associate II
  • 1479 Views
BLUENRG-M2SA kernel configuration linux
Hello everyone. I am using the BLUENRG-M2SA with the processor SAMA5D27 Cortex-A5 in a linux system. I communicate with it by uart. I have set the kernel like the ubuntu site advises (https://ubuntu.com/core/docs/bluez/reference/device-enablement/lin...
SParr.1 by Associate II
  • 2594 Views
I am planning to test S2LP in Tx mode and want to see the data transmitted on the oscilloscope. How do I provide the synchronization signal for the oscilloscope?
I am planning to test S2LP in Tx mode. I was considering to observe the data transmitted by S2LP in Txmode on an oscilloscope. How do I provide the synchronization signal for the oscilloscope? Or alternatively, is there any way to what is the data tr...
NAwari by Associate II
  • 1707 Views
S2LP with external PA?
Is there any available circuit/schematic where external PA has been used to enhance the power output of S2LP at 868 MHz operations? I am trying to understand how do I work around BALUN suggested for S2LP 868 MHz (FKI868V2 kit) with an external PA?
  • 1704 Views
