BlueNRG-LP DK SW issue with power management drivers causing high current draw after exiting DEEPSTOP mode
I'm using the BlueNRG-LP DK SW package to work on a STEVAL-IDB011V1 dev kit. I'm testing the HAL power management drivers.The problem I'm having is using HAL_PWR_MNGR_Request() to enter deepstop mode (which is called POWER_SAVE_LEVEL_STOP_WITH_TIMER...
Jerrold1 by Associate II
  • 1030 Views
Resolved! How to update BLE sensor demo example code value
Hi @Sebastien DENOUAL​ ​ I have example code BLE sensor demo in that they have 3 sensor value and one free fall characteristics. One is acceleration , temp, press, and free fall. The acceleration sensor value is Conntiniously updating over the app on...
Resolved! BlueNRG-LP Extended Broadcast
Hello, I'm trying to program a STEVAL-IDB011V1 board for a broadcast role with extended advertising and Coded PHY. But something is wrong in my GAP set configuration because when I run my program I got this status from aci_gap_set_advertising_config...
DLoza.2 by Associate III
  • 2277 Views
BLUENRG-LP Antenna Matching Guide
I am developing a new product using BLUENRG-355AC and need some help regarding the antenna matching circuit. I am planning to use an external 2.4GHz antenna connected to a SMA connector on the board. The BLUENRG-LP series has two evaluation boards ST...
MManj.1 by Associate II
  • 2028 Views
