Resolved! Firmware upgrade over the air.
Hello community,I got a project to do as my Master Thesis on Firmware upgrade over the air.I know how to write linker script, bootloader check free space and configure every peripheral etc. What attributes one look for when working with firmware upgr...
Vmere.1 by Senior
  • 1211 Views
Ultrasound solution and details
Hi,We are looking for 64-channel ultrasound solution for medical imaging. I found your proposal as in the block diagram, as well as the ICs, like STHV64SW and STHV1600. However, I need much more details in order to move forwards. Do you have the full...
LZhan.13 by Associate
  • 832 Views
HI, I use DSP28335 to read the rtc M41T94 chip time, the mode is (00 or 11), but the oscilloscope decoding always returns FF or 00. Hope to get your help. thanks ZGH
The DSP28335 processor is used to communicate with the M41T94 real-time clock chip (RTC). The RTC uses SPI for communication. The basic configuration method is to write command + write time, then read command + read time, but the read time is basical...
GZhan.6 by Associate
  • 990 Views
