2016-06-27 1:52 AM
Hi All,
I am new in BlueNrg but not in developing C and I want to work withNUCLEOF411 and BlueNrg IDB041A1 board. Unfortunately I use Linux and Idon't want to buy IAR system. First step: I tried to download demo (en.x-cube-ble1.zip). I wonder, there is no Makefile in it:(I found .bin and .hex files for demos, I can flash it, and it works well with BlueNrg Android application. Because there is no Makefile, I tried to find some infos and I found Carmine Noviello's site. I can compile and flash the sensordemo based on his tutorial, but it cannot works well. Sometimes it cannot starts:''Program received signal SIGTRAP, Trace/breakpoint trap.0x080015e2 in call_host (arg=0x2000ffac, reason=1) at ../system/include/arm/semihosting.h:8080 asm volatile (''sometimes it can enter on master loop, but it isn't visible for android software. I tried to switch on/off NEW_SERVICES switch too.It is very interesting, the original sensordemo hex file is 28938bytes length. The compiled hex file is 55718 bytes length.Second steps:I found mbed.org ''how to start bluenrg shield'' athttps://developer.mbed.org/teams/ST-Americas-mbed-Team/wiki/Getting-Started-with-BLE-IDB04A1I can compile and flash it to the board, but it is not visible forandroid software. The attached terminal there are some messages:Initialising btle_init>>So, my question is that, where can I found a correct tutorial and demofor compiling and testing blueNRG? I would like to use linux and gnugcc. thxZamek #bluenrg-demo-tutorialWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
