2023-01-31 9:33 PM
I am doing a manipulator project with VL53L4CD and meet a problem. Could you please take some time to check? I really appreciate it for your support, thanks.
The issue is I can not measure the correct distance result because status is error and always equal to 7.
My Time of Flight Sensors is VL53L4CD.
I look up datasheet then find the reason is described as wrapped target, phase does not match. I don't understand the meaning of phase here.
Does the sensor fail to measure due to environment conditions? So what should I do?
2023-02-01 6:58 AM
You can find some details about the error here. You will get an explanation of wrapped target.
Anne
2023-02-02 1:08 AM
Thank you
