Imaging (sensors)
ToF on 3mm cover glass?
Hi, we have a project which must be equiped with 3mm thick cover glass. However, all notes and recommendations we found are about 1mm and max. 2mm. Would it be possible with a good calibration to run a ToF on 3mm glass?Which sensor would be best for ...
MHarr.9 by Associate II
  • 2732 Views
Effect of "timing butget" using VL53L1CX
I use the "short mode" and set the timing butget to 100 ms. Every second I start a new measure with VL53L1X_StartRanging. With VL53L1X_GetRangeStatus() I poll for a new measure. But when I measure the time that is needed for a range it is only 20 ms....
MKlag.1 by Associate
  • 1321 Views
I have a few questions about VL53L1CB.
1. I would like to know the release date of VL53L1CB and VL53L1CX.2. If you check the datasheet of the VL53L1CB, it is listed as the VL53L1 model, but the CB is missing. I want to know the reason. What does CB mean?Is there a datasheet dedicated to t...
sLee.401 by Associate
  • 1599 Views
timing jitter - VL53L3CX
Hello Community,Any documentation on timing jitter in relation to this sensor ? In a single range how does changes in the timing jitter affect the spread of peaks ?For two different histograms generated from two different distance, does slight change...
v++ by Associate II
  • 3325 Views
VL53L5CX basic ranging doesn't return any results
For the past week or so I've been trying to interface this sensor. I've reached a point where I get no errors during the firmware download and initialisation of this sensor. Using the example, I then start ranging (which gives a 255 error?), but when...
ALohr.1 by Associate II
  • 2898 Views
Frame rate - VL53L3CX
For VL53L3CX, how do we measure frame rate during ranging ? I have reviewed datasheet but no information found in this.Any help or information will be very much appreciated.
v++ by Associate II
  • 1569 Views
