Imaging (sensors)
Resolved! Unable to read ID Register directly
Hello,  As suggested in my last post here, I am trying to read the ID Value of a VL53L1X sensor. I get a read failure when I attempt to read the register. Strangely, I have slightly modified code that I am using to read the ID register of a VL53l0X w...
mttdarko by Associate II
  • 2508 Views
Resolved! Selecting ST ToF Modules for Distance Measurement During Free Fall
Hello community, I am working on a project that involves measuring a precise distance of 2 meters from the ground during an object’s free fall. I am considering using Time-of-Flight (ToF) modules from ST for this purpose and would like some guidance ...
Vect by Associate
  • 1406 Views
Resolved! VL6180X laser compliance documents
Hello,We are using the VL6180X in a IVD product and need laser test certificate documents to show the range sensor is class 1 and safe for the user. Can you send me a test reports for this part? I see a CDRH report posted for VL53L1, but couldn't fin...
AJB721 by Associate
  • 1363 Views
Resolved! VL53L8 - programmable ROI
Hii ,Does VL53L8 tof sensor support ROI selection or Reduced FoV as VL53L1 , if yes how do i do it ?Thanks,Poornima B
Poornima by Associate
  • 1341 Views
VL53L7CX range fluctuation
Hi I am developing a commercial footfall counter based on the VL53L7CX and ESP32.The API is (Version : VL53L7CX_1.2.10)I have produced a mockup using the VL53L7CX breakout board.IOVCC is 3.3 voltsI am using the on board regulator for AVDD powered fro...
VL53L4CD - Signal is below the defined threshold
Hey,I have a custom made board/device which is using 4x VL53L4CD Tof Sensors to measure the distance. I have trouble to calibrate the sensors correctly or get correct values from them from time to time. Sometimes it works well - sometimes it does not...
DrD00m by Associate III
  • 11530 Views
  • 27 replies
VL53L3CX measurement never ready
I've been trying to get my VL53L3CX to communicate with my ESP32-S3. I'm using esp-idf and ported https://github.com/stm32duino/VL53L3CX by rewriting the I2C and GPIO code for esp-idf. As far as I can tell, I'm successfully communicating with the VL5...
k1ra by Associate
  • 1594 Views
Resolved! VL6180 EOL, VL53 as subtitute
Hello,We received an EOL status notification for our current sensor VL6180 and I found the VL53L4CD as a substitute for this TOF proximity sensor. We would like to know how long this device will be active, as the VL6180 is now on EOL.Can you also con...
