Imaging (sensors)
Resolved! vl53l1 measurement takes up to 30 seconds
Hi, I use 2 VL53L1 Sensoren via I2C for measuring distance. At first I used a raspberry pi and the provided API and it seems to work properly and all fine. Since I need to reduce my power consumption I migrated my Code to an atmega644 and therfore I ...
Resolved! The definition of Depth in VL53L TOF sensors
Hello, I have a FUNDAMENTAL question: TOF VL53 series  sensors report a depth map. Is the depth the "Euclidean distance from the origin (0, 0, 0) to the point (X,Y,Z)" ? or is the orthogonal distance from the camera chip plane to the measured point a...
Yunlion by Associate II
  • 469 Views
ST VD56G3 Captured Image Overlapping
Hi  I am using ST VD56G3 camera to capture .raw image from NXP IMX8m embedded board. I was able to capture the raw file using the following command. gst-launch-1.0 -e v4l2src device=/dev/video2 ! "video/x-raw, format=NV12, width=1120, height=1360, fr...
STM32F401RE + X-NUCLEO-53L7A1
Hi all, I am new to STM32 programming. I have been able to write a driver for an ultrasonic distance sensor, flash the board, and measure distance, in Rust. Now, I am trying to get a STM32F401RE to talk to a X-NUCLEO-53L7A1 ToF sensor, connected via ...
Resolved! 3d scanning with VL53L5CX
Hello, I have started working with the VL53L5CX ToF sensor, for 3d scanning. I have successfully interfaced the sensor with MCU and am able to read the data from it. I have read the datasheet and um2884 user manual as well which explains the differen...
ak_g by Associate
  • 1341 Views
Resolved! How to distinguish VL53L5CX and VL53L7CX after assembly?
Hi,is there a way to distinguish both mentioned sensors other than by complex optical measurements (they have different FOVs)? We have built devices with both types of sensors and our firmware calculates x/y/z coordinates from the reported distances ...
PJDE by Associate
  • 690 Views
