Imaging (sensors)
Timing configuration difference between VL53L1X ULD and API
We are currently investigating an issue with corrupted measurement results of an VL53L1X using the ULD API in short range mode. The sensor delivers results with status ok but completelely wrong ranging values at target distances exceeding the range o...
mf101 by Associate II
  • 1950 Views
Resolved! How to obtain a low-res depth image with a VL53L* sensor?
Hi there, is it possible with any of the currently manufactured ToF sensors of the VL53L* family and the software that is available to private customers to obtain a depth image, or the raw sensor values for each SPAD to reconstruct a depth image?I ex...
Step by Associate II
  • 3555 Views
VL53L1X singleshot measurement
Currently we are using the VL53L1X ULD API which only supports autonomous mode. We would prefer to have a manually controlled measurement flow like the following:Start singleshot measurementWait for interruptRead measurement data and clear interruptS...
  • 2004 Views
VL53L1X Data_init() return error
Hi forum,I am working on nrf52 , I was communicate with sensor through I2C.GPIO_configuration:- nrf_gpio_cfg_output(VSHUT); nrf_gpio_pin_write(VSHUT,0); nrf_gpio_pin_write(VSHUT,1); nrf_delay_ms(10); nrf_gpio_input_disconnect(TRACEDATA1);// gpio1 int...
DANDE.1 by Associate II
  • 5543 Views
Print data from Lidar sensor
Hello guysi want to print lidar sensor data (digital) to virtual port.what is the way to do it.do i need to change the received data to string?TIA
Resolved! VL6180 vs VL6180X
I am interested to know the key differences between the VL6180 and VL6180X ToF sensors.I understand that the VL6180 has no ALS and also it appears to operate over a longer range.Is it as accurate in the 0-100mm range as the VL6180X?Thank you
LWill.3 by Associate II
  • 3028 Views
VL53L5 TOF Sensor on Notebook
Hi,I have a laptop equipped with VL53L5, I want to use it, but after my query, I found that there is no relevant instance executed in Win10, and no softwares can be used on ST official websiteI know that VL53L5 is a new product, I am thinking that it...
4Chad.1 by Associate
  • 1401 Views
