2024-11-07 2:21 AM - edited 2024-11-07 2:23 AM
Currently using the STA8100_MF_DRAW_Binary_Image_v5_9_22 firmware, could you demonstrate commands to specify the received NMEA data streams, such as $GPGSV, or commands to disable all data streams & control the output frequency? It would be great if there is any GitHub initialization code available.
Thank you.
2024-11-21 1:59 PM
To access STA8100 firmware configuration, please reach out ST Sales and Marketing. The documents specifying the bit fields to set are not intended for mass market.
2024-11-07 3:39 AM
Check firmware docs for $PSTM configuration methods, or Teseo Suite for command code templates/output forms.
I'll lock at docs when at a computer.
2024-11-21 1:59 PM
