2024-10-19 1:08 PM - last edited on 2024-10-19 1:18 PM by STTwo-32
Hello all,
I have a GNSS1A1 board with the LIV3F module. My problem is, in teseo suite my gps location shows up accurately, however when I look at the messages it is clear to me my location in those messages are far away from me.
How is this possible? I am trying to make a software that interprets the data and my location in there shows up completely flawed. Even tried adding a triangulating function.
Difference:
0.2 degrees lateral
0.18 degrees longitudal
2024-10-19 1:24 PM
You've given no example of output vs your interpretation.
Probably because you aren't decoding the NMEA properly, it reports a DDDMM.mmmm form and you're trying to decode directly as a DDD.ddddd (Decimal Degrees) form.
There are 60 minutes in a degree, not 100
