The post editor loves blank lines so much, it puts them on everything
BarryWhit
Lead II
See for example this helpful post by @Andrew Neil
https://community.st.com/t5/stm32-mcus-products/stm32-ic-s-unique-id/m-p/657372/highlight/true#M239912
Andrew is a stand-up guy. He wouldn't be this sloppy when posting, but it's not his fault.
Whenever someone inserts a "Code" block, in order to get syntax highlighting. Any subsequent edit of the post adds an extra blank line above and below the block. It doesn't matter if you erase them when you edit. They can only grow,
like the mythical hydra. The only solution is to remove the code nlock entirely, delete all the blank lines and save the post. Then edit it again, and re-insert the code-block. Then, you must never-ever-ever edit that post again, or you'll have to go through it all over.
Come on ST. 2024. AI. 32TOPS in every phone within 5 years. Can we fix the editor please???
- If someone's post helped resolve your issue, please thank them by clicking "Accept as Solution".
- Please post an update with details once you've solved your issue. Your experience may help others.
1 ACCEPTED SOLUTION
Accepted Solutions
Andrew Neil
Super User
Indeed - Already reported by @waclawek.jan:
https://community.st.com/t5/feedback-forum/don-t-litter-posts-with-whitespace-empty-paragraphs-inserted/td-p/574693
EDIT:
There's a workaround to somewhat mitigate it:
https://community.st.com/t5/feedback-forum/don-t-litter-posts-with-whitespace-empty-paragraphs-inserted/m-p/668939/highlight/true#M1347
but the forum keeps adding them back in.
2 REPLIES 2
BarryWhit
Lead II
Like this
Give me some space!
... See?
Andrew Neil
Super User
EDIT:
