Attachments stuck on "virus scan in progress..."
Andrew Neil
Super User
Here - since at least 10:56 GMT:
https://community.st.com/t5/stm32-mcus-boards-and-hardware/nucelo-stm32h563zit6-internal-temperature-sensor-issue/m-p/861430
and here - since at least 08:38 GMT:
https://community.st.com/t5/others-stm32-mcus-related/facing-difficulties-in-interfacing-stm32l433-mcu-to-vcnl4040-i2c/m-p/861339
That's just the 2 I've seen ...
1 ACCEPTED SOLUTION
Accepted Solutions
Lina_DABASINSKAITE
Community manager
Dear @Andrew Neil@Issamos, all,
I am pleased to inform you that the issue has been resolved, and all previous attachments, as well as new ones, are loading correctly.
Thank you for your patience while waiting for this fix. I hope you can now resume the topics that were disrupted due to this issue.
If the behavior persists, please let me know by sharing the URL to the thread.
Thank you,
Lina
9 REPLIES 9
Lina_DABASINSKAITE
Community manager
Hi @Andrew Neil,
Thanks a lot for sharing this. I've escalated this to support team for troubleshooting.
Let me know if you notice these issues yourself.
Thank you,
Lina
Andrew Neil
Super User
Another one here:
https://community.st.com/t5/stm32-mcus-products/st-link-firmware-will-not-upgrade/td-p/861526
Same behavior for all attachements on the Community posts.
Best Regards.
II
Andrew Neil
Super User
Still broken today.
eg, here @Imen.D asked @yuichiro to attach an ioc file - and it's stuck:
https://community.st.com/t5/stm32cubemx-mcus/i2c1-pin-assignment-on-pb8-pb9-is-removed-when-spi1-is-enabled/m-p/862460/highlight/true#M34446
Thank you, @Andrew Neil, I added to the ongoing investigation. In the meantime, we are looking for a safe alternative for file exchange.
I will keep you all postend on this.
Apologies for the inconvenience.
Regards,
Lina
Lina_DABASINSKAITE
Community manager
Dear @Andrew Neil and @Issamos,
The root cause of the issue has been identified, and the team is deploying a fix within the next few hours. Once completed, all stuck attachments will process normally, restoring access.
File attachments can still be uploaded and will process successfully. We apologize for the delays and their impact on the discussions.
I will confirm completion of the fix in a separate update.
Thank you,
Lina
Sadly not:
https://community.st.com/t5/stm32cubeide-mcus/stm32g431cbu-section-bss-will-not-fit-in-region-ram/m-p/863392/highlight/true#M39940
Indeed @Andrew Neil, the solution did not work out yesterday as expected and is back with the troubleshooting team. I am very sorry it takes so long. I hope the next attempt will be successful.
Lina_DABASINSKAITE
Community manager
Thank you,
Lina
