2021-10-20 3:49 AM
Hi Gln,
Am trying to modify the ASC code for keyword spotting. I can see the ASC dataset which is 30sec audio data with sample rate 44.1khz whereas am using 1 sec audio dataset with sample rate 16khz. After feature extraction, am getting value "0". Should I change anything in the logmel spectrogram code? Please help.
ASC code links:
https://colab.research.google.com/drive/1lBca6J1kUTNG8MmaM_TTPV8M-5IXdy7Y#scrollTo=1pZBm4W3khO8
