2021-04-28 9:12 AM
2021-04-30 2:24 AM
Hi @TS.2 ,
you might use the High Speed Datalog function pack, as reported in the user manual UM2688 (p. 31), you can use an already available python script (folder \Utilities\Python_SDK\).
In particular, the hsdatalog_to_unico.py can prepare data to be imported into Unico-GUI. You can find it in the, but I attach it to this post for completeness.
As second step, you might need to charge again the .ucf file on the STWIN, in order to configure the ISM330DHCX.
For this scope, you can check the procedure I've reported here below:
Run the example with STWIN and HSDatalog
HSDatalog is a high speed data logging command line application for the STWIN board.
HSDatalog also allows configuring ISM330DHCX Machine learning Core and reading the output of the selected algorithm.
Here all the required steps to run a MLC example through STWIN and HSDatalog:
If my reply answered your question, please click on Select as Best at the bottom of this post. This will help other users with the same issue to find the answer faster.
-Eleon
2021-04-30 2:24 AM
Hi @TS.2 ,
-Eleon
2021-05-06 4:05 AM
Hi @TS.2 ,
did you make some progression with your issue, according to the above answer?
-Eleon
