2023-10-15 8:03 AM
I am doing a project for fall detectino using the MLC in the LSM6DSOX. However, i noticed that the output of the sensor for the accelerometer show values on the 1000 mg range for the z axis. I would like to calibrate the sensro but the only way I found to do this is using the Motion_AC library. However, I don't know how I could use this library in the Arduino environment and more precisely for the board Nano RP2040 connect. Does anybody know how to perfomr the calibration?. Thanks.
2023-10-15 8:05 AM
The main issue is I want the calibrated values to go into the MLC for classification. I could use a general code for calibration but I need the calibrated values from the accelerometer to go into the MLC.
2023-10-19 4:05 AM
Hi @SRodr.4 .
Why do you want to do a calibration? 1000mg on the Z axis is expected.
