Edge AI
Ask questions and find answers on how to deploy, debug, and optimize AI models on ST microcontrollers, microprocessors, and smart sensors.
[Short Survey] Please give us your feedbacks on ST model Zoo Services
Hi everyone,   In order to help our developers understand how their work is used and what to do in order to improve model zoo, we kindly ask you to look at this survey about ST Model Zoo Services.   Link of the survey: https://docs.google.com/forms/d...
Resolved! Nucleo F746 SPI
HelloI am using NUCLEO-F746ZG. SPI1 and ETH are set with CubeMX and programmed with EWARM.SPI1 will not work if there is an ETH setting ”MX_ETH_Init();”. Do you know the reason?
shank by Associate III
  • 1753 Views
X-CUBE-AI 8.1 is out!
We are pleased to announce that the latest version of STM32Cube.AI is now available.You can download it here. What is new in X-CUBE-AI 8.1.0? TensorFlow 2.12 and Keras.io 2.12ONNX Runtime 1.15.0Host PC system: adding support for MacOS ARM systemInclu...
Resolved! Connecting STEVAL-MKI109V3 to other motherboard
Hello, I would like to know what possibilities the STEVAL-MKI109V3 has for connecting to other motherboards. From what I understand, this board (STEVAL-MKI109V3) is used a bridge between a sensor, for example, the LSM6DSOX, and a PC, but I would like...
SRodr.4 by Associate II
  • 1653 Views
Resolved! STEVAL-MKI109V3 wireless communication
Hello,I am currently utilizing the LSM6DSV16x kit alongside an MKI109V3 evaluation board and UNICO-GUI. I am wondering if there is a way to use UNICO-GUI with wireless communication, as I need to gather data. Any suggestions or advice would be greatl...
FKara.3 by Senior
  • 1465 Views
MLC Output Delay
Hello,I have recently conducted a test on the activity recognition task using the ST library with ESP32 MCU. Although it functions correctly, there are noticeable delays before action recognition occurs. I am seeking advice on how to address this iss...
FKara.3 by Senior
  • 1380 Views
error when analyzing the .onnx model in stm32cubeMX by stm32cube.AI
Hi, Thanks for your attention. I am analyzing the .onnx format model but an error occurs. I try to reinstall the stm32cubeMX but it doesn't help. The part of architecture is: Here is the log information. Can you help me with this problem? @Romain LE ...
BHuan.3 by Associate III
  • 8601 Views
X-CUBE-AI: what is the input buffer format?
Hi,I'm trying to test X-CUBE-AI on my Stm32F429ZI nucleo board. I'm using Stm32CubeMX, Stm32CubeIDE.Setup: stmnist_v1.h5, I've PNG files for this dataset.At first I'd like to test the AI routines with in-memory buffer so I'd like to know what is the ...
Test User by Associate III
  • 3499 Views
Artificial intelligence on raspberry pi
Hi team. May you kindly assist how to eliminate false positive for a face recognition project  is it my code which is the problem or something else. For white people I am getting true positives but for blacks, only false positives.
Inaccurate step count vales while using LSM6DSOX built in pedometer
Hi,I am currently using LSM6DSOX and its features like MLC and built in pedometer in a project, MLC works just fine but when I am walking whilts LSM6DSOX is in a 40 to 50 degrees tilted position on my wrist, pedometer misses around half of the steps ...
enis_isik by Associate II
  • 1215 Views
