2026-05-01 4:41 AM - edited 2026-05-01 7:11 AM
I am using sr6p3e and I tried to access Gicr registers but I got aport exception, I tried several things like check if clock control the module and if there is a protection registers but I didn't find anything, I know that it use axim for interface so I tried to write on another module GTM registers after making necessary configuration but I got sameh issue
I check the startup code coming with mcal and found it configure mpu for Gicr and prephiral section and when I apply it in my code it solve the issue
I don't need to use mpu, is there another way to access Gicr and gtm ?
2026-05-03 8:46 AM
Hello Safifi,
SR6 products are still under NDA and can't be discussed in this public forum.
For any question, please contact your local ST support, and do not post information/questions in this public forum.
Thank you.
Best regards,
Francesco
2026-05-03 8:46 AM
Hello Safifi,
Thank you.
Best regards,
Francesco
