2015-10-07 5:48 AM
I am using
Universal Debug Engine v4.02.07
for programming the flash with SPC560D MCU withPLS USB/JTAG adapter
. Where can I find the checksum value for the obj file (.elf or .hex or .out)? Which menu of the tool has this information listed? any document for the UDE tool?Thanks in advance.Mike.2015-10-09 1:52 AM
Is there any generic tool available for knowing the checksum value of the generated output file (.elf or .hex or .bin etc)?
Thanks.Mike.2015-10-12 3:04 AM
Hello Mike ,
Sorry for the late answer , my alert settings was brokenyou can use cksum <FILENAME> to generate a checksum on defined file.or md5sum.exe (cygwin tools)i am checking on PLS Side Best regards Erwan2015-10-13 6:12 AM
Hello Erwan,
Any updates on the PLS side? Whether the two executables mentioned below are available with SPC5Studio?Thanks.Mike.2015-11-02 7:35 AM
Hello Mike ,
md5sum.exe is coming from cygwin tools. PLS is using your own checksum calculation to check if the elf file has been touched and updated. Best regards ErwanWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
