2013-03-15 4:29 PM
I'm trying to import into SPC5 Studio a project before built into Standard Eclipse enviroment but is not clear what should i do.
Should i import it as standard eclipse project or as SPC5 studio project? Thanks2013-03-19 4:27 AM
From the ''File'' menu select ''Import...'' and then ''General->Existing Projects into Workspace''. From the dialog select the root of the project(s) and select the ones you want to import. This procedure is not specific of SPC5Studio, it works in any Eclipse based environment. GiovanniWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
