2023-05-31 4:50 AM
Is it possible to change the white theme to a dark theme in SPC5Studio?
2023-05-31 5:18 AM
This should be possible, please check and try this thread.
Hope that helps?
/Peter
2023-05-31 5:39 AM
Dear Peter,
Can you please give me directions to change the dark theme?
Pasindu
2023-05-31 6:16 AM
OK, maybe the information at the link provided is not sufficient.
In fact you just need to install Devstyle, which has been discussed very often here in the Community - just search for Devstyle.
Devstyle requires the installation of Oxygen:
Then try installing DevStyle and check if it installs fine: Help > Eclipse Marketplace --> Devstyle
Good luck!
/Peter
