Automotive MCUs
Resolved! Enabling lockstep core in SPC570S MCU
Hi,I am prototyping on a SPC570S-DISP development board, and I am trying to enable the checker core in the MCU. I read the technical reference manual, and it has stated that the checker core can be enabled from the UTEST DCF memory registers. How ca...
NBula.1 by Associate III
  • 3047 Views
Write access to memory range refused
Tried to flash SPC560B50L5 MCU with example program "SPC560BCxx_RLA PWM-ICU Test Application" UDE STK returns write access to memory range is refused. Loaded Bootloader program in ude stk , then flashed pwm program to mcu it gets programed.But every ...
$AK by Associate III
  • 1446 Views
Resolved! SPC5studio build warining analysis configuration don't take effect.
I use SPC5studio to build code, there are some configurations of warning I want to reset, but it don't take effect. The configuration of path is my_project-->Properities-->C/C++ General-->Code Analysis-->Use project settings. I wonder wether is it ri...
Ljich.1 by Associate
  • 1235 Views
Resolved! Non-intrusif scanf()
Hello,I'm working on the SPC574S-DISP board, I've set up FreeRTOS and I would like to have a way to do a non-intrusive scanf.I would like the program to keep running and wait for a key to be pressed to access a submenu.The problem is that with scanf(...
Bastien1 by Associate III
  • 1962 Views
Resolved! PWM with DMA in SPC560B54L5 MCU
I have used PWM in SPC560 MCU and in addition to that DMA is required for ws2811 addressable led.how to use pwm with DMA.Thanks in AdvanceRegards,AK
  • 1306 Views
Resolved! RX interrupt with Runtime-IO
Hello, I would like to know if it possible to make RX interrupt with the serial driver initialize thanks to Runtime-IO Component RLA ?In reality, I want to use scanf() with interrupt to make it non-blocking.Thank you by advanceRespectfully Bastien
  • 1705 Views
