Automotive MCUs
Resolved! How to SYNC PWM?
Hello, i have now this working code on SPC560P without sync flag. pwm_lld_start(&PWMD1, &pwm_config_pwm_cfg0); pwm_lld_start(&PWMD2, &pwm_config_pwm_cfg0); pwm_lld_start(&PWMD3, &pwm_config_pwm_cfg0); pwm_lld_start(&PWMD4, &pwm_config_...
How to put struct object in absolute memory address?
My old project using 16bit infineon MCU with tasking c166, now I am moving to spc5 with free gnu gcc spc5studio.I am working with typedef struct.typedef struct { struct { struct { INT16 Rpm[6]; INT16 Load[7]; INT16 Threshold[6]; }...
jmary by Associate III
  • 6333 Views
  • 11 replies
Hi Guys, I am working on SPC584B-DISP Board.In this board i need bootloader option so that i am try to use example SPC584Bxx_RLA Bootloader Test Application for Discovery 2 .In this example download code from serial UART .
In this I can able to download bin file from UART next step jump to app in this step not working if any one have idea please help .......Thanks advance ...
Ravi S by Associate II
  • 16829 Views
  • 52 replies
FLEXPWM channel setting
Hi,Can anyone explain to me about this flexpwm setting? Now my led just in condition of logic HIGH, not turning off or fade, it just ON.
Angle by Associate II
  • 853 Views
Anyone have SPC5-L9177A-K01 schematic?
Hi, recently I bought SPC5-L9177A-K01 development board from Arrow, But I received the board only. ​Is there anyone have the board schematic, since the schematics is different from SPC5-L9177A-K02 board. ​Already contact Arrow, still no result.
  • 901 Views
Wake up and Sleep
HISPC560P44L3 -used in my project . Requirement :when external signal ( 0 to 1 ) - system wake up and Run .When external signal ( 1 to 0 ) - System go to sleep mode ( Low power Mode ).External pin connected with NMI pin number 1 . ( SPC560P44L3 - 10...
RRama.3 by Associate
  • 2341 Views
