Automotive MCUs
SPC5Studio marketplace and Update Site by proxy.
Posted on May 04, 2016 at 15:18Dear all ,Set your proxy in Windows ==> Preferences (General ==> Network Connections)you have to set your proxy in HTTP/HTTPS only (manual)if you have still some connexions issues on some your corporate proxies ,for SP...
ADC convertion when input 0 voltage
Posted on February 29, 2016 at 16:12Good morning to everyone,I am trying to understand a possible problem I have with tha AD converter of the SPC56ELxx.I am working on a board where an input current is used to set an input voltage to trhe ADC conver...
Programmatically erase flash memory block
Posted on March 02, 2016 at 15:57 Good morning to everyone. I am trying to erase a flash memory block. I am try not to use the drivers. As now, I managed to program individual memory cells of the flash memory with storage data, following ...
SPC5Studio 4.1.0 compilation errors from generated code
Posted on April 27, 2016 at 09:34When I use SPC5Studio 4.1.0 to generate files for a project that worked with 4.0.0 and try to compile with gcc, I get the following errorscc1.exe: error: bad value (e200z0) for -mcpuIf I replace the line in the Makef...
flash resident bootloader
Posted on April 26, 2016 at 11:30hi st,I want to program spc560p40 through flexcan, and on every start-up the program can be upgraded.I plan to store the boot code into falsh sector 0, and application code into other sectors. However I am not clear ...
CRC function on SPC56EL70L5
Posted on April 27, 2016 at 10:19I try to use SPC56EL70L5-DISP(master) to communicate another board(slave) through SPI. CRC-8 , polynomial, C(x) = x8 + x2 + x1 + 1 , is needed for the SPI last byte. I attempt to use the SPC56EL70L3 build-in CRC func...
tony2 by Associate
  • 2172 Views
SPC5Studio 5.2.1 is available
Posted on April 25, 2016 at 10:04Dear All ,SPC5Studio 5.2.1 is available - http://www2.st.com/content/st_com/en/products/development-tools/software-development-tools/spc5-software-development-tools/spc5-studio.html*** Highlights ***SPC5 Studio, vers...
SPC560D Power consumption
Posted on April 05, 2016 at 13:16Hi CommunityI have some issues/questions about the power consumption of the SPC560D40L1 CPU. I found this document on the ST-Websitehttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/application...
SPC5 FLASH/DEBUG TOOLS - connector pinout
Posted on March 21, 2016 at 15:12Hello,I am working with SPC560D40L3 microcontroller and I have some questions on how to design the interface between my board (which design is still in work) and the SPC5 UDESTK and the SPCconnect tools.Please find m...
SPC5Studio Marketplace and SPC5Studio update site DOWN
Posted on April 13, 2016 at 14:30Dear All ,SPC5Studio marketplace and SPC5Studio update site is down this morningthe host provider is located on Cloudforge servers.Sorry , for the issue.           Best regards                      Erwan
