Automotive MCUs
SPC5 and L9907 current budget recommended?
Hello!I am developing a motor controller driver running on a 48V Li-Ion battery. I want to choose the right regulators. Unfortunately I can not use the MCTK-01 as reference because it is supplied via the mains.What is the current budget I should plan...
CTara by Associate II
  • 1102 Views
Need help in CAN driver development for spc58xx series
Hello expert, I have just started working on Eiger controller and wanted to develop CAN driver for spc58xx series controller. I do have referrence manual but this device seems to be more complex than others. do you guys have any other technical docum...
vchav.17 by Associate
  • 1205 Views
Unable to install Flash Driver
Hello, I did a fresh install of SPC5Studio 5.8 and I'm trying to install the Flash Driver from Eclipse Marketplace.But all I get is a:No repository found at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio/updates5.I also tried to lo...
SPC58 flash and debugging tool
Hello experts,Can SPC5-FLASH and SPC5-UDE be used on SPC58 series MCUs? For example, can the SPC-UDEDEBG tool quoted here be used for SPC58 boards other than the Discovery kit?https://www.st.com/en/development-tools/spc5-udedebg.html I am looking for...
YC by Associate
  • 1784 Views
SPC560B jtag debugging
Hello friendsI am working on a SPC560B50L5 microcontroller and I want to learn debugging it.According to"AN4035 Application note" I can do a single step by loading appropriate values in CPUSCR registers. I do everything that is mentioned in Document....
sdrad by Associate II
  • 918 Views
Stuck in SPCSetRunMode() when debugger is attached.
Using the PLS USB/JTAG probe on a SPC56EL, I'm unable to debug because I'm stuck into SPCSetRunMode(). Unplugging the probe, and resetting the MCU make the FreeRTOS demo run nicely. I'm aware of some errata about low-power issues, but I'm not sure th...
nono240 by Associate II
  • 798 Views
