2018-10-01 7:39 AM
Hello friends
I am working on a SPC560B50L5 microcontroller and I want to learn debugging it.
According to"AN4035 Application note" I can do a single step by loading appropriate values in CPUSCR registers. I do everything that is mentioned in Document. for example to
read a value from memory with lwz instruction I Enable OnCE, entere Debug Mode
and enable external tool debugging and then put appropriate values in WBBRlow, IR
and CTL , then I perform a Go+NoExit Write
in OCMD. If everything Is OK(that I think is) I should have the read value in
WBBRlow register. But I see no updates in WBBRlow value.
Would you please help me if I’m wrong…
Thanks so much
